Dover TRA (EGGN J0558/19) / showing UAV-only restrictions
DaveWhite
DaveWhite
Posts: 53, Visits: 205
Thanks, Tim - that clarifies.
I've added a note to the current depiction, but this is a RA(T) rather than an "unmanned aircraft scheduled" so we can't do anything automatic currently.
DaveWhite
DaveWhite
Apologies - this should have been posted in the "Charts & Aeronautical Data" forum.
DaveWhite
DaveWhite
This NOTAMed RA(T) is applicable to UAVs only, which the wording in the NOTAM tab does makes clear.
However it is much less clear on the chart, and hovering over it or pressing for "What's Here" does not mention UAVs at all, or quote the NOTAM - it appears to be applicable to all aircraft.
Is it possible for SkyDemon to annotate the (presumably auto-generated) RA(T) description to make this clear? The RA(T) is in place until  late January.
In the longer term, if UAV-only RA(T)s such as this are going to become more common, I wonder if there can be a standard way of discriminating between them at a glance?  Perhaps using the blue "quadcopter" icon you already use for other NOTAMed "Unmanned Aircraft Scheduled" areas?
Edited 11/12/2019 2:50:26 PM by DaveWhite
