This NOTAMed RA(T) is applicable to UAVs only, which the wording in the NOTAM tab does makes clear.
However it is much less clear on the chart, and hovering over it or pressing for "What's Here" does not mention UAVs at all, or quote the NOTAM - it appears to be applicable to all aircraft.
Is it possible for SkyDemon to annotate the (presumably auto-generated) RA(T) description to make this clear? The RA(T) is in place until late January.
In the longer term, if UAV-only RA(T)s such as this are going to become more common, I wonder if there can be a standard way of discriminating between them at a glance? Perhaps using the blue "quadcopter" icon you already use for other NOTAMed "Unmanned Aircraft Scheduled" areas?
