Track radial
216engineer
2
Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)Forum Member (27 reputation)
Posts: 3, Visits: 0
Yep. I totally understand where you are coming from.
I used the HSI function and found that it gives the correct indication of the radial/track whether flying into or out from the point.
Is it possible to change the scale of the HSI? Eg a choice of 5, 2.5 and 1.25nm for the 5 dots either side
Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)Too Much Forum (9.8K reputation)
Posts: 619, Visits: 30K
Technically, the radial is the line that emanates from the station; in that respect SD does it right.
I suspect the confusion is caused by being used to a VOR display, where one can select a radial, and see a 'to' or 'from' indication according to which side of the station you are. SD has no such explicit indicator, so think of the colour of the line as representing that indicator i.e. magenta = 'from', white = 'to'.
Edited 11/11/2019 1:48:12 PM by grahamb
I suppose it depends upon what radial you enter; one going in or one going out (according to your flight direction). I cannot comment on what other software does.
216engineer
2
Posts: 3, Visits: 0
I’ve just found this feature on SD having used similar OBS on other aircraft GPS units. However I was a little confused initially with the white coloured line leading to the waypoint and the magenta line leading out of the waypoint. Other units would have the colours reversed or am I mistaken?
