NOTAMS
Ian Brierley
Ian Brierley
Too Much Forum (288 reputation)Too Much Forum (288 reputation)Too Much Forum (288 reputation)Too Much Forum (288 reputation)Too Much Forum (288 reputation)Too Much Forum (288 reputation)Too Much Forum (288 reputation)Too Much Forum (288 reputation)Too Much Forum (288 reputation)
Posts: 5, Visits: 30
Tim Dawson - 11/6/2019 11:38:44 AM
In that case if you've planned a flight at 2400 feet everything up to 400ft will be shown, this is by design. You can always change the vertical bit if you want to see fewer NOTAMs that you're flying clear of vertically.
OK, thank you.  So I'll reduce this to 500 ft and see less NOTAMs.
Posts: 8.2K, Visits: 9.5K
Ian Brierley
Ian Brierley
Tim Dawson - 11/5/2019 11:59:51 AM
What settings have you configured for your narrow route brief?
10nm
2000 ft
Ian Brierley
Ian Brierley
Tim Dawson - 11/4/2019 11:01:51 AM
They won't show up in your briefing if you plan a flight significantly higher than them. Is that not what you're finding?
Hi Tim, that's not what I'm finding.  If I plan a local flight at 2400 feet (which I have to do to keep below the LTMA) I get all the Obstacles Erected including those to FL 06, FL03 etc.  And of course, all the Missile (fireworks) advices today, most below 1000 feet.
Ian Brierley
Ian Brierley
May I make a suggestion for an additional filter for NOTAMS?  While I understand that for helicopters and some low level flyers these are very important, there are many NOTAMS now applicable below say 1000 feet and I would like to be able to filter these out and concentrate on the more relevant ones to my flying.
