+xIn that case if you've planned a flight at 2400 feet everything up to 400ft will be shown, this is by design. You can always change the vertical bit if you want to see fewer NOTAMs that you're flying clear of vertically.
OK, thank you. So I'll reduce this to 500 ft and see less NOTAMs.
