+xThank you for the explanation. The reason we did not bring that window across from the PC version to the mobile version is that hardly anybody uses it on the PC version; it's redundant. In fact we have given thought to removing it, on many occasions.
You asked why we are conservative. Good software has as simple a user interface as possible, and as few options as possible. Well-established and popular software such as SkyDemon is subject to an extremely conservative viewpoint on the notion of making changes, especially changes to the top-level user interface, as the proven view of the developers is that it isn't broken, so we shouldn't be trying to fix it.
Having said that, our users are very much in charge, and if a large volume of them all want something, it almost always gets done. Large in this case being at least 10% of people (in our estimation) and a fairly constant incoming barrage (for want of a better word) of suggestions all relating to it, whether on this forum on others, by telephone or email.
I don't agree with You Tim. For REAL world pilots flight plan is saint. Unless you're not a pilot Tim (which I presume - so far You didn't answer my question), it can look redundant
For Your reflection, I fly by the numbers and map, not by VR that is only a useful gadget.
Ok, I don't wanna argue........I have easier suggestion instead. Can You at least expand 'next point info' on a top of map screen?
Right now it is: NEXT: <turn point name> ,
can it be: NEXT: <turn point name> + <next turn HDG>
It is a very small change so I don't think it'll brake Your highly conservative approach on altering main map view.
Right now info about next turn (leg) heading is not sufficiently visible unless ofc You start clicking. Like I already said I don't wanna click. I want to see it all the time and mainly concentrate on flying a rig which is not equipped with autopilot, not either on remembering this number or on looking for it while holding a yoke.
I know that next leg HDG shows up when particular leg becomes active but it appears too late and also disappears very fast. It is simply wrongly done. Sometimes air is rough and You have to fight with a plane to hold it steady. And when I finally want to make a turn this number is already gone off the screen and You have to visit pilot log or precisely touch magenta line to view it (risking entering leg edit mode at the same time).
