SD 3.12.5.182 iOS 12.2 bug in airfield page / notam section
This was indeed a bug in 3.12.5, fixed overnight with a 3.12.6 update. It's worth contacting technical support (just in case you didn't) about such urgent things as we do not regularly monitor this forum. Thanks for reporting it though.
emporer
e
Posts: 69, Visits: 5
I also want to thank for the cleanup and redesign of the airport information page, great work, Thanks
deltasierra
deltasierra
Too Much Forum (308 reputation)Too Much Forum (308 reputation)Too Much Forum (308 reputation)Too Much Forum (308 reputation)Too Much Forum (308 reputation)Too Much Forum (308 reputation)Too Much Forum (308 reputation)Too Much Forum (308 reputation)Too Much Forum (308 reputation)
Posts: 9, Visits: 8
Fixed with the latest .183 release. Great work Skydemon!
That’s Devops in action!
deltasierra
deltasierra
Posts: 9, Visits: 8
I’m also experiencing the same issue with an iPad Mini 4 with the same SkyDemon and IOS versions quoted above. Another small big is that the Favourite Airfields feature doesn’t seem to work . I’ve tried pinning an airfield as a favourite and it will not list it under favourites.
Edited 5/2/2019 6:24:59 PM by deltasierra
abbrax
a
Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)Forum Member (31 reputation)
Posts: 3, Visits: 2
Hello SkyDemon Team,
I think I found a small bug in the notam tab when opened from the airfield information page. On my iPad, wether it is in landscape or portrait mode, there is no "back" arrow in the upper left corner. To go back or open an other airfield page, i have to select it with a long tab on the map.
Since it does not happen on my iphone (there is a "back" arrow) I think it has something to do with the screen width.
Best regards
abbrax
