SkyDemon Flight Planning
Import .gpx files after editing
duncans
duncans
posted 4/23/2019 11:29:27 AM
HOT
Visits: 30
Forgot to turn off flight logging so ended up with my drive home recorded on the flight log.
To edit the drive out of the log, I exported to a gpx file, opened in Notepad and deleted the segments relating to the drive. That leaves me with a clean gpx file which displays the correct flight log when I import it back in to SD.
How do I save this as a SD flightlog? I tried renaming the .gpx as a .flightlog file and saving in the skydemon/logs folder, but it doesn't work. Couldn't find any 'save log file' functionality to put a .flightlog file in to the skydemon/logs folder.
posted 4/24/2019 10:13:00 AM
Posts: 8.2K,
Visits: 9.7K
You can't recreate a SkyDemon flight log like that. When you export one into GPX format you lose much of the proprietary data in the original log, such as aircraft, planned route, pilot name, course changes, all sorts of stuff beyond simple geographical data that gets exported to GPX.
Exporting to GPX is designed so that you can view the geographical part of a flightlog in other software. It's not a way of editing logs and then importing them back into the SkyDemon system.
duncans
Have you tried renaming the file before importing it back into SD?
4/23/2019 7:33:28 PM
You can't recreate a SkyDemon flight log like that. When you export...
So we know how we can NOT do that, but how can we actually edit the...
marekol
9/28/2019 9:12:39 PM
As you recognized, you cannot edit the .flightlog file, which btw was...
9/29/2019 6:59:06 AM
I don't need to edit it freely, I just need to correct some specific...
marekol
10/3/2019 5:37:10 PM
The flight logs in SkyDemon are not designed to be user-editable. Your...
9/30/2019 10:11:03 AM
The complication is that there can legitimately be more than one...
10/4/2019 10:01:12 AM
Yes, that's true, that is normal and quite usual situation. But after...
marekol
10/7/2019 3:59:54 PM
I'm pleased to say I've been able to do something about this. We are...
10/8/2019 2:57:20 PM
It will not fix the old logs, but it seems to be a good solution for...
marekol
10/8/2019 6:41:08 PM
