Charts and Aeronautical Data
TMA Frequencies
TMA Frequencies
TMA Frequencies
Frans
Frans
posted 2/27/2019 11:08:09 AM
HOT
Visits: 28
I've noticed that some of the TMA frequencies in Switzerland does not match with the correct ATC-unit. For example, around Zurich, SD mentions "Zurich Information", but this is only the FIS-frequency and they can't give clearances by themselves. For TMA crossings "Zurich Terminal" is the correct ATC-unit to contact in TMA-airspace around Zurich for VFR-traffic in class C. For crossings within the non-TMA and non-CTR airspaces (class C and D), "Zurich Delta" is the correct ATC-unit. They give for example clearances to cross corridors and in general class C airspace above FL100/FL130.
In Germany, the non-CTR airspaces in class D and C doesn't have published frequencies for VFR-charts at all, but they are mentioned within the IFR-arrival/departure charts as Radar frequency. For example around Suttgart, this would be "Langen Radar" on 125,050 or 119,200 and around Cologne/Bonn, this would be also "Langen Radar", but now on 135,350. The problem here is the German ATC-company "DFS", which want to force VFR-pilots to contact FIS first prior to cross airspace class C or D.
Frans
Frans
posted 3/5/2019 11:25:51 AM
Visits: 28
That would be great! I hope to be there on friday, but I'm a bit unsure because of some workprojects. I will let you know in advance, as soon as I've managed the projectplan for next month.
Edited
3/5/2019 11:26:20 AM by
Frans
TMA Frequencies
Frans
We generally match what the official AIP states as the primary contact...
2/27/2019 4:32:52 PM
I've checked the frequencies around Zurich between SkyDemon and the...
Frans
3/4/2019 10:31:02 AM
It would be possible, but we would have to implement a clear policy on...
3/4/2019 10:47:55 AM
That would be great! I hope to be there on friday, but I'm a bit...
Frans
Unfortunately, I couldn't make it to the AERO in Friedrichshafen due...
Frans
5/14/2019 5:07:19 PM
There are now two separate matters under discussion here, which is...
5/16/2019 9:49:16 AM
Are there any updates regarding this topic? Regarding Switzerland:...
Frans
10/28/2019 4:52:02 PM
Regarding the original topic of this thread, the official line from...
11/4/2019 11:26:41 AM
Yes, I will do so. ;-)
Frans
11/5/2019 7:32:34 PM
They're not officially documented anywhere, which is a problem because...
11/6/2019 10:56:28 AM
Germany: Yes, they are documented, however, only on the IFR plates of...
Frans
11/6/2019 1:50:33 PM
Possible yes, but that doesn't make it sustainable. If we did as you...
11/6/2019 4:10:41 PM
Good to know. I was in the expectation that once you have configured...
Frans
11/6/2019 6:01:02 PM
I'm not completely sure what you're referring to. Looking at page 36...
11/7/2019 11:25:18 AM
Yes, the definition of the airspaces are maintained at the beginning...
Frans
11/7/2019 1:12:58 PM
Sorry, the split between airspace definitions and area control...
11/11/2019 12:08:58 PM
Thanks for the feedback. I can understand your point of view, however,...
Frans
11/20/2019 4:22:43 PM
The underlying issue appears to be that the DFS do not want you to use...
11/21/2019 12:23:12 PM
