Bug in simulator on Ipad ?
EU001939
E
Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)Forum Member (42 reputation)
Posts: 9, Visits: 2
I can’t seem to figure out the following problem with the simulator function on an Ipad skydemon (version 3.11.1.149)
Not sure if it is a bug or I am doing something wrong:
Following example : planning a route that has a TrkT=265, Wind is 011/16 and the planning gives a magnetic heading of 273. So far no problem. departure time is now
Now when I start the simulator, the plane takes a TrkT=257, wind is 011/16 , Magnetic is 257 as well, and the heading bug on the compass is on 265. But the plane keep flying 257 and so deviates from the route. Whatever I do to change the direction of the plane it keeps going back to a magnetic heading of 257. The leg properties remain the same as in planning mode.
Could it be that the simulation mode is somehow mixing up drift and drift correction ?
Or am I missing something ?
Txs
Tony
Posts: 619, Visits: 13K
The simulator has always behaved in this fashion, on every platform, but I'm not sure why.
PC – Windows 10 (Home Ed) Version 22H2, Build 19045.4355
, SD 3.16.13.0
Posts: 7.8K, Visits: 8.4K
Your aircraft gets blown about by the wind.
EU001939
E
Posts: 9, Visits: 2
Hello Tim,
If the plane drifts because of the wind then the magnetic heading on your compass would be equal to the track. So a bit confusing with the compass at the bottom of the screen as in fact it shows TrueT as well. but I guess that’s the case as well in flight (never checked) as the gps is the only source of input...so understand that...
anyway, Is there a way to force the plane to just follow the track , ie the heading bug ?
Ie either by :
-forcing the plane on the calculated magnetic heading. (I know we can change that by tapping the plane, but it always revert back to track + drift ) . so in fact have it working like the autopilot would do in a real plane.
-chang the wind conditions ? Because now it always takes the current wind conditions, regardless of the flight time you had planned, and regardless of the manual weather conditions set in the planning options ?
Or to complex to implement ?
Txs
Tony
No. The simulator is a bit of fun. It's not designed to do anything precisely, nor is the manner it operates documented or guaranteed not to change. It roughly flies the route you planned, with a bit of randomless thrown in.
