Clive
Visits: 6
+xThere hasn't been any development of this feature since this thread was started. Next time we look at it, it's likely we will implement a tool to email yourself the report, or a CSV file, or both. Thanks for the prompt reply Tim, Appreciate the position. Regards, Clive
Posts: 8.2K,
Visits: 9.8K
Clive
Visits: 6
Was anything done with this so I can send a summery to myself by E mail? I don't have a windows PC so the phone is the only place I can get it working. Thanks Clive
clenfant
Visits: 3
Well, to generate an excel spreadsheet, or at least a csv txt file, and send it via email, would be great The goal is to be able to use, and manipulate, the datas.
Posts: 8.2K,
Visits: 9.8K
It's a cloud function. We looked into this recently and there isn't an easy way to share the output of it. One option would be to have a field on the output which allowed you to email it to yourself - that's the best idea we've come up with at present.
Visits: 388
I understand it was transformed into a cloud function with all b&b, so shouldn't the data synchronize with the PC version, where one can grab it in the Skydemon folders?
raphis
Visits: 0
Experienced the same "issue" today. The share button in the log summary allows only printing and no export/share with other applications. This is a bit strange as the function of this button isn't consistent - the same icon in the ipad PDF viewer allows to share the content.
clenfant
Visits: 3
+x+xCopy and paste should work, and the functionality is just the same on the PC version of SkyDemon. Thanks Tim for your answer.
It should, but it doesn't. To do a copy / paste, I need to send the summary by email from the iPAD to my laptop, then I can copy-paste to excel. But form the iPAD, I can only sent to a printer. Don't know why, as previously it was possible to sent by email. And on the PC, when I want to see the summary, on have only a blank page, so I can't do anything. Ok, for the PC, the issue was hat I didn't had the last version ! Fixed, very sorry you can forget this issue, the summary is correctly generated now.
Still an issue from the iPad, I will investigate on my side too.
Regards, clenfant
clenfant
Visits: 3
Posts: 8.2K,
Visits: 9.8K
