clenfant
Visits: 3
Hi, Previously, it was possible to use the "share" function under IPAD to sent the log summary by mail for example. I tried to do it recently, but it was not possible anymore. The only option available was to print it. Don't know if it is related to skydemon application, or a bug from my IPAD.
Can you let me know if this a new limitation coming from Skydemon, or if I need to investigate on the IPAD side ?
Posts: 8.2K,
Visits: 9.8K
Possibly from the SkyDemon side. We changed the Log Summary a couple of months back so that it works across all your logs stored in the cloud, which means it's now a cloud-based function.
clenfant
Visits: 3
+xPossibly from the SkyDemon side. We changed the Log Summary a couple of months back so that it works across all your logs stored in the cloud, which means it's now a cloud-based function. Agreed, but so how to do at least a copy / paste of the data into an excel spreadsheet for example ? Prior the update, it was possible to sent the summary by email, then I was able to copy and paste into excel.
Please note that as I couldn't sent the summary from the IPAD, I tried to get it from the Windows Skydemon software, but all I've got is an empty page
Posts: 8.2K,
Visits: 9.8K
Copy and paste should work, and the functionality is just the same on the PC version of SkyDemon.
clenfant
Visits: 3
+xCopy and paste should work, and the functionality is just the same on the PC version of SkyDemon. Thanks Tim for your answer.
It should, but it doesn't. To do a copy / paste, I need to send the summary by email from the iPAD to my laptop, then I can copy-paste to excel. But form the iPAD, I can only sent to a printer. Don't know why, as previously it was possible to sent by email. And on the PC, when I want to see the summary, on have only a blank page, so I can't do anything.
clenfant
Visits: 3
+x+xCopy and paste should work, and the functionality is just the same on the PC version of SkyDemon. Thanks Tim for your answer.
It should, but it doesn't. To do a copy / paste, I need to send the summary by email from the iPAD to my laptop, then I can copy-paste to excel. But form the iPAD, I can only sent to a printer. Don't know why, as previously it was possible to sent by email. And on the PC, when I want to see the summary, on have only a blank page, so I can't do anything. Ok, for the PC, the issue was hat I didn't had the last version ! Fixed, very sorry you can forget this issue, the summary is correctly generated now.
Still an issue from the iPad, I will investigate on my side too.
Regards, clenfant
raphis
Visits: 0
Experienced the same "issue" today. The share button in the log summary allows only printing and no export/share with other applications. This is a bit strange as the function of this button isn't consistent - the same icon in the ipad PDF viewer allows to share the content.
Visits: 388
I understand it was transformed into a cloud function with all b&b, so shouldn't the data synchronize with the PC version, where one can grab it in the Skydemon folders?
Posts: 8.2K,
Visits: 9.8K
It's a cloud function. We looked into this recently and there isn't an easy way to share the output of it. One option would be to have a field on the output which allowed you to email it to yourself - that's the best idea we've come up with at present.
clenfant
Visits: 3
Well, to generate an excel spreadsheet, or at least a csv txt file, and send it via email, would be great The goal is to be able to use, and manipulate, the datas.
