SkyDemon Flight Planning
default POB count for flight plans
Mike McPherson
Mike McPherson
posted 6/28/2018 8:13:09 AM
Visits: 141
whenever I create a flight plan it comes up with 3 POB
how can I change this?
also
when I edit an aircraft (new equipment) and click OK it doesn't seem to do anything
I would expect either
a) a separate Save button
b) OK to save and close the edit window
cheers
_______________________________
Mike McP G-BHLX SD 3.8.1 iPad retina
posted 7/11/2018 11:10:46 AM
Posts: 8.2K,
Visits: 9.7K
There is no Save button on SkyDemon PC software, which you confirmed above was what you were talking about, so I'm afraid I am still in the dark here.
mmcp42
POB is estimated based on the weights you've entered in weight and...
7/4/2018 10:40:12 AM
ah ok I'll check the weights everything in my post on Windows 10 PC...
mmcp42
7/4/2018 8:07:17 PM
Ok, I've just tried editing the equipment on the PC software and the...
7/5/2018 11:36:02 AM
Win 10 PC, SD 3.9.5.0 top menu click Aircraft select one click edit...
mmcp42
7/5/2018 3:27:04 PM
When you say "seems to do nothing" the aircraft profile is in fact...
7/9/2018 8:34:33 AM
I was expecting Save and Close especially as the only other button is...
mmcp42
7/9/2018 12:47:28 PM
I think we must be talking at cross purposes because I really don't...
7/10/2018 10:44:19 AM
but but but :) you edit the aircraft you hit save all good so far...
mmcp42
7/10/2018 4:27:52 PM
There is no Save button on SkyDemon PC software, which you confirmed...
