default POB count for flight plans
Mike McPherson
Mike McPherson
Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)Too Much Forum (5.5K reputation)
Posts: 47, Visits: 141
whenever I create a flight plan it comes up with 3 POB
h‌ow can I change this?
a‌lso
w‌hen I edit an aircraft (new equipment) and click OK it doesn't seem to do anything
I‌ would expect either
a‌) a separate Save ‌button
b‌) OK to save and close the edit window
c‌heers‌
_______________________________
Mike McP G-BHLX SD 3.8.1 iPad retina
When you say "seems to do nothing" the aircraft profile is in fact saved and your equipment changes are persisted. What exactly are you expecting to happen? I did just try exactly your steps and although there isn't a confirmation window saying "you've changed x y and z" the changes are saved as I would expect them to be.
Mike McPherson
Mike McPherson
Tim Dawson - 7/9/2018 8:34:33 AM
I was expecting Save and Close
especially as the only other button is Cancel
cheers
