GPX, KML, KMZ Ex-/Import with Google Earth
Jörg Hofmann
Jörg Hofmann
Too Much Forum (725 reputation)Too Much Forum (725 reputation)Too Much Forum (725 reputation)Too Much Forum (725 reputation)Too Much Forum (725 reputation)Too Much Forum (725 reputation)Too Much Forum (725 reputation)Too Much Forum (725 reputation)Too Much Forum (725 reputation)
Posts: 8, Visits: 5
trallala666 - 6/6/2018 9:16:43 PM
So - this works. Great. But the way is a bit long :-( Anyway, THANK you so much, pgroell!
Let me summarize the steps:
1) Open the SkyDemon outputed GPX File with a Text-Editor.
2) rep‌lace lines like <skd:level type="A" value="4500" /> with  <altitude>4500</altitude>
3) remove <extensions> and  </extensions> lines. This has to been done!
4) save the GPX File and close it
5) load up this GPX File here: http://www.gpsvisualizer.com/map_input?form=googleearth right side of the window!
6) change these settings in the left half window, middle section: Altitude mode  to "extruded" . choose also line width and desired colour and change the units (left window on top) to nautical!
7) klick on "Create KML File" on the right side. Wait.
8) open / import the produced Kml File to Google Earth
9) Enjoy ;-)
Edit: Point 2) has to be changed the data from feet to meter. Correct it must be:
2) rep‌lace lines like <skd:level type="A" value="4500" /> with  <altitude>1372</altitude>
otherw‌ise the line in Google Earth won't be comporable in heights and elevations.
emporer
e
Posts: 69, Visits: 5
trallala666 - 6/6/2018 10:39:05 PM
emporer - 6/6/2018 10:03:20 PM
I have for you this workaround:
- plan your route in SD
-simulate the flight in SD or fly it in a flight sim
- a log file will be generated by SD
- select the log file and open it in google earth, you will see your track elevated over ground in whatever altitude you were simulating it
Pls what? For about 3 hr. Trip i should wait at least 2hr. to get a log file written? Crazy...Hehe
In flight sim you can increase the simulation speed, so you will have the log -date for an 3 h flight in 9 min
