No warning sound when airspace/obstacle ahead
citylight
citylight
Too Much Forum (237 reputation)Too Much Forum (237 reputation)Too Much Forum (237 reputation)Too Much Forum (237 reputation)Too Much Forum (237 reputation)Too Much Forum (237 reputation)Too Much Forum (237 reputation)Too Much Forum (237 reputation)Too Much Forum (237 reputation)
Posts: 2, Visits: 6
I am using SkyDemon on my iPad mini and iPhone 6. I have problems to get audio warning when entering controlled airspace or if terrain is ahead. I can see only the message on the display. I have tried it only in Simulation mode.
And yes: audio/ringtones are both set to max :-).
I assume there is sound support, or am I wrong?
Thanks and regards,
Guido
Posts: 8.2K, Visits: 9.5K
SkyDemon always plays sounds associated with such warnings. You should check your iOS settings as alert sounds must somehow be disabled on your device.
citylight
citylight
Posts: 2, Visits: 6
Yes, found the problem. Thanks!
Dabinett
Dabinett
Too Much Forum (423 reputation)Too Much Forum (423 reputation)Too Much Forum (423 reputation)Too Much Forum (423 reputation)Too Much Forum (423 reputation)Too Much Forum (423 reputation)Too Much Forum (423 reputation)Too Much Forum (423 reputation)Too Much Forum (423 reputation)
Posts: 6, Visits: 12
What settings did you change?
LukasK
L
Too Much Forum (387 reputation)Too Much Forum (387 reputation)Too Much Forum (387 reputation)Too Much Forum (387 reputation)Too Much Forum (387 reputation)Too Much Forum (387 reputation)Too Much Forum (387 reputation)Too Much Forum (387 reputation)Too Much Forum (387 reputation)
Posts: 5, Visits: 2
I don't have warning sounds on my iPad as well so would be much appreciated if someone could guide me to the solution.
M‌any thanks!
It's probably that your alert volume has been turned down (a hardware setting, not in SkyDemon). Our support will know more if you can't find that setting.
LukasK
L
Posts: 5, Visits: 2
Tim Dawson - 5/10/2018 11:11:35 AM
I just realised that under Settings >  there is a alert volume bar. its not the same as the normal sound volume that you can change with the two buttons on the side.
