Control when Skydemon thinks I have landed
pmkarlss
Too Much Forum (948 reputation)Too Much Forum (948 reputation)Too Much Forum (948 reputation)Too Much Forum (948 reputation)Too Much Forum (948 reputation)Too Much Forum (948 reputation)Too Much Forum (948 reputation)Too Much Forum (948 reputation)Too Much Forum (948 reputation)
Posts: 10, Visits: 1
Skydemon seems to think I am still flying while having landed minutes ago. As long as I taxi in ~20+ knots or so it thinks I am airborne, hence the landing time is incorrect which is quite annoying when I am to write in my logbook.... Is there a way to control this setting?
T67M
T67M
Posts: 206, Visits: 3.2K
Taxi at a more reasonable speed? Most light aircraft should be taxied at less than 10 knots. Even commercial airlines rarely exceed 20 knots on the ground, and the typically don't have prop clearance issues to worry about.
drnicolas
drnicolas
Posts: 99, Visits: 114
T67M - 4/26/2018 1:15:24 PM
Upon this posting , I took a closer look at my logs:
I see no difference between Log Start/Take off and Log Stop/Landing. It is always the same time.
Is thsi behaviour intended? there seems to be no Blocks off/on Timing.
And I definitely tax with less than 20 knots.
E.g. at the Aero I had about 40 Minutes! time queuing up for departure, so there is a large differencd between‌‌‌‌‌‌ block-time and flight-time in this case.
If you are sitting stationary but your GPS is telling SkyDemon your speed is 26 knots, then your GPS is the problem.
SkyDemon has a pretty good‌‌ algorithm for determining when you have landed, but speed is part of that calculation. If you're doing 26 knots, that doesn't sound like a taxi.
pmkarlss
Tim Dawson - 4/30/2018 9:13:17 AM
This flightlog was actually recorded in a CRJ, and we did not always taxi at 26 kts, but nevertheless the recorded landing time and the actual landing time differed almost 10 mins. Would be nice to be able to control this otherwise very nice feature.
I'm afraid the feature is designed to work for the vast majority of use cases out there. If you're regularly taxiing at that sort of speed, the feature simply isn't for you, sorry. We don't generally add options to make such features work in edge cases because options confuse matters.
