Visits: 239
Using iPad Mini 4: When I select Route>Open, the Open box appears but is only deep enough to show the first four routes saved, although it can be scrolled to show the rest. However, once a route is showing, if I then select Route>Open (or just Route) the box is much larger showing the first eleven routes. I suspect there is a minor bug somewhere- not critical but would be good to resolve sometime.
