By Skyboy999 - 4/13/2018 3:22:28 PM
Using iPad Mini 4: When I select Route>Open, the Open box appears but is only deep enough to show the first four routes saved, although it can be scrolled to show the rest. However, once a route is showing, if I then select Route>Open (or just Route) the box is much larger showing the first eleven routes. I suspect there is a minor bug somewhere- not critical but would be good to resolve sometime.
By Tim Dawson - 4/16/2018 4:25:23 PM
Could you contact customer support about this please?
