Viewing Logged Notes v3.9.1
plume_tray
plume_tray
Posts: 116, Visits: 434
Other than in the Debriefing Pack, how do we view notes that we've logged? Reason being, on a busy flight, I might need to go back and check what I've logged.
‌Is it possible to edit or delete a logged note? In case of typos or errors?
plume_tray
plume_tray
Can't find anything in the user manual, however I just realised something else.
‌SD automatically starts logging (which is a good thing), but to input a user note, you must first select "Log Engine On" or "Log Off Blocks" before the "Write note" option is available in the menu.
‌What happens when you forget to select either "Log Engine On" or "Log Off Blocks" and you are half way into a flight and you want to write a note? The user manual says "Log Engine On" or "Log Off Blocks" overrides the log times in the Debriefing Pack.
‌The "Write note" option needs display in the menu immediately after pressing "Go Flying/Fly"?
