Hello
A perhaps a minor issue.
On: PC, SkyDemon 3.8.2.0, Win10 - 64
Setup - GPS Navigation Options - GPS Hardware
Port: COMxxxx
The listing in the combobox is wrong - e.g. seems to be wrongly setting up the 0x00 delimiter to strings.
Example:
COM1 <<< OK
COM10 <<< OK
COM70 <<< wrong - this shall be COM7 (and in Win it is, yet it seems the SD keeps the data from the previous field - the last '0' char)
COM80 <<< same issue
COM11 <<< OK
COM12 <<< OK
How it shall look like:
COM1
COM10
COM7
COM8
COM11
COM12
Actually, it breaks even more (further every time the window itself is open), see the screenshot:
Not sure it this is a win32 API issue under Win10/64,
or something in SD.
Luckily the ComboBox could be editted manually, which has saved the day.
So just FYI, I guess, hope it helps.
Also, could a direct "raw COM port capture to a file" feature be added (even if only to a Win EXE version of SD), right in there; of course to fully work along the "Go Flying" mode. That would be so great and useful !
a.
