Garmin GDL39 Integration
yappmeister
y
Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)Too Much Forum (336 reputation)
Posts: 3, Visits: 22
First of all - love the software, been using for 2 years now!
Just got a GDL 39 3D and currently forced to use Garmin Pilot‌ to make operate the device. However disappointingly I can't export logs from this (and generally is expensive and not as good as SD....obvs). Using it for traffic info is the primary purpose but I had really hoped to get more accurate GPS data into my logs.
Is there any chance that the traffic info (ADSB-In) and more importantly the GPS information ‌‌from a GDL 39 could be integrated with an android/iOS device running SD? Presumably over the Bluetooth connection. I've already resorted to bodging a cable and logging NMEA183 data using a Raspberry Pi but it seems like a waste of what is actually quite nice hardware (give Garmin some dues...).
TIA
J‌‌‌‌
Posts: 8.2K, Visits: 9.5K
https://www.uavionix.com/products/skyecho/
Th‌at device has its own power supply, does both ADS/B in and out and is fully compatible with SkyDemon.‌
TouchTheSky
T
Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)Too Much Forum (5.8K reputation)
Posts: 153, Visits: 4.5K
Tim Dawson - 8/2/2017 10:07:55 AM
But not approved for other countries in Europe yet:
"‌Portable ADS-B transmit capability is currently only approved for use in the United Kingdom under CAP 1391."
T67M
T67M
Posts: 206, Visits: 3.2K
TouchTheSky - 8/2/2017 12:29:03 PM
And even within the UK, only in aircraft which do NOT have a Mode S transponder.
Pigei
P
Posts: 10, Visits: 38
Pigei
P
Provided that You affirm that Skydemon is supporting Scout, why the manufacturer says that it's only compatible with Foreflight ?
yappmeister - 7/25/2017 8:01:18 AM
Tim Dawson - 7/26/2017 2:45:34 PM
yappmeister - 8/1/2017 8:56:20 AM
TouchTheSky - 8/1/2017 2:42:27 PM
TouchTheSky - 8/2/2017 6:18:28 AM
T67M - 8/2/2017 11:48:03 PM
pgppvt@gmail.com - 8/22/2017 9:51:19 PM
pgppvt@gmail.com - 8/22/2017 10:06:03 PM
yappmeister - 8/6/2017 7:47:19 PM
Tim Dawson - 8/23/2017 1:52:09 PM
             At the moment available only in UK
pgppvt@gmail.com - 8/23/2017 7:36:04 PM
     Where from?
Tim Dawson - 8/30/2017 9:26:43 AM
             Italy
pgppvt@gmail.com - 8/30/2017 9:33:37 AM
Tim Dawson - 8/30/2017 9:45:08 AM
             I agree
pgppvt@gmail.com - 8/30/2017 1:34:57 PM
