toolbars.
FF
F
Posts: 20, Visits: 3
Good morning, the toolbars on my pc disappeared, how can I make they appear again?
Thanks‌
George Reid
George Reid
Posts: 113, Visits: 1.6K
FF - 7/21/2017 9:49:46 AM
Thanks‌
Go to the menu line (Route     Mapping     etc) at the top of the screen.  Right Click on the blank area of this line.  You will then get an option to select the toolbars.
George E A Reid
FF
F
GEAR - 7/21/2017 10:07:16 AM
Thanks‌
Thank you George, but I explained the problem badly! I can not see the following pages: Notam, Weather, W&B, Flight Details, Route Plan and Virtual Radar.
Thanks‌
George Reid
George Reid
FF - 7/21/2017 11:47:33 AM
Thanks‌
Thanks‌
Check that the virtual radar window is visible. If necessary, enlarge it.  You should find the missing tabs below the virtual radar.  From there, you can drag them to where you want to have them located.
George E A Reid
FF
F
GEAR - 7/21/2017 12:53:36 PM
Thanks‌
Thanks‌
I tried but negative, the radar and other windows are not visible!
Federico‌
FF
F
I do not have the mini Windows!
George Reid
George Reid
FF - 7/21/2017 1:12:18 PM
can you post a screenshot
George E A Reid
Posts: 8.2K, Visits: 9.6K
Try deleting your settings file, while SkyDemon is closed. You'll find the file at C:\Users\YourName\AppData\Roaming\Divelements Limited\SkyDemon Plan and it's called settings.xml. Next time you open SkyDemon your environment window will have reset to its default state.
FF
F
Tim Dawson - 7/24/2017 8:49:44 AM
Thank you Tim, it was the right solution!
