+xTry deleting your settings file, while SkyDemon is closed. You'll find the file at C:\Users\YourName\AppData\Roaming\Divelements Limited\SkyDemon Plan and it's called settings.xml. Next time you open SkyDemon your environment window will have reset to its default state.
Thank you Tim, it was the right solution!
