Weather when flying
Claus, it sounds like you've probably just turned off the wind instrument. In flight, Setup -> Instruments.
pseudonym
pseudonym
Posts: 50, Visits: 189
flieger-claus - 5/7/2017 2:09:51 PM
In the past I had a very useful wind barb / arrow on the left bottom side on the screen. I cannot find a menu to see it again....in google play it is still to see in the sample screenshot. I use Android 3.7.1.28802. For me it is not so helpful in navigation before every flight to switch on weather overlays. And to search the map where is a wind barb...
I am looking forward for a tipp to get  the wind barb again at the left bottom side! Claus
Offline?
flieger-claus
flieger-claus
Posts: 15, Visits: 47
There is no way to increase or decrease the opacity of the rainfall layer. It is not designed for tactical use in flight, and should not be used for that purpose.
Edited 5/16/2016 3:05:07 PM by Tim Dawson
radma011
radma011
Posts: 33, Visits: 141
And is there a way to show rainfall a little transparent so one can still see the map information underneath?
Edited 5/13/2016 3:31:45 PM by radma011
pseudonym
pseudonym
While in flight mode, click the skydemon globe in the upper left, click the weather menue item (second from bottom), find the "turn on weather overlay while"
I'm using the actual iphone-version, iirc, this feature is new/changed location
Martin Bech
Martin Bech
Posts: 152, Visits: 352
If I use the weather function when flying nothing is showing on the map(arrows)?
