Runway directions
DA40
DA40
Posts: 15, Visits: 260
Tim Dawson - 2/28/2017 11:34:16 AM
The example in the original post is quite a good one. A simple airfield with a roughly north-south runway, displayed north up on a portrait airfield chart, looks really silly. It's just a thin featureless runway taking up the whole of the page, with the useful textual information then forced onto the next page. It's an appalling use of space.
First of all, I don´t understand why the layuot should be portrait.
Why not always use landscape instead? Easier to handle when you are flying, just fold the paper and you will have airfield diagram on one side, always north up and the text info on the other side.
Talking about airfield chart that´s looks silly, here´s an example of that.
ESMC Kristianstad, runway direction 01/19, asphalt runway 2215 mtrs.
Tim, at least put a very prominent compass rose or north pointing arrow on the page.
Apparently you have situations in mind in which a north-up orientation wouldn't work in a portrait layout. Can you post an example?
Thanks, -- Chris.
For this airfield, you're right. For others, this isn't the case. We have a lot of different airfield orientations and a lot of user requirements to cater for, and we do the best we can.
I also find it confusing to view an airfield diagram in anything but north up orientation. Given the fact that there isn't much information contained in the chart (it's mostly just a line showing the runway orientation) it wouldn't hurt much to show a slightly shorter line but in the "correct" orientation.
-- Chris.‌‌
DA40
DA40
Tim Dawson - 2/20/2017 10:30:39 AM
We orientate airfield diagrams either north up or west up depending upon how they'll best fit on the page, allowing the most other information to also be displayed.
But if you use landscape layout, you could have the airfield diagram on the left side, always north up, and the other textual information on the right side?
DA40
DA40
First of all, Sky Demon is overall a great product!
However, there is one thing that I think should be changed:
In PC-version:
When you right click on an airfield you can choose the option "information".
When you choose Information you get a description of the airfield with frequencies and runway information.
The depiction of the runway direction is not oriented relative to north, which is very confusing.
An example:
EKSJO / Ranneslatt (ESMC)
The text below the picture is correct, Runway 01/19
But the picture above the textual information shows the runway direction 280/100, which is very confusing.
If you change the orientation of the layout by 90 degrees, the runway direction will be ok, but the text will be hard to read.....
It is the same on all airfields, at least in Sweden.
I went back to an earlier version of SD (3.5.0.0), and in that version the presentation of airfield information is correct.
Skydemon is probably the only provider of airport information that doesn´t orient map (background) layouts to north.
Compare with Jeppesen layout, i e plates depicting runway direction is always on a map (background) which is oriented to north.
