Navaigon 8410 Help required.
Aviator32
Aviator32
Too Much Forum (428 reputation)Too Much Forum (428 reputation)Too Much Forum (428 reputation)Too Much Forum (428 reputation)Too Much Forum (428 reputation)Too Much Forum (428 reputation)Too Much Forum (428 reputation)Too Much Forum (428 reputation)Too Much Forum (428 reputation)
Posts: 4, Visits: 446
I am a relative newbie although I have successfully installed SD on a 7" Chinese unit and that works perfectly. However I wanted to try it on a Navigon 8410 due to the very bright screen on these units, as although the 7" display is a much better size for my old eyes, is not bright enough to be readable in the air.
I installed SD on a Navigon 8410 - with a big thanks to Pink Leader for the memory card files - and it is working OK .... of sorts. The programme starts and runs fine and I have to say at this point I am extremely impressed with the software. It is way ahead of anything else out there including the £1,000+ offerings. However when I want to edit, save or need to type in a destination the keyboard does not appear as it does on the 7" unit. The same if I click on the toggle keyboard under system menu as nothing happens. Another problem, but one I could live with, is that clicking the exit button on the system menu causes the Navigon to freeze which also happens if I click exit on the start up screen and needs to be switched off to reset.
This happens on both version 1.4.4 and the beta 1.4.5 so I believe it to be the unit software rather than SD but if that makes me sound like I know what I am talking about, then I can assure you that I do not!
Hope someone has had the same problem and knows a fix?
jkveenstra
jkveenstra
Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)Too Much Forum (719 reputation)
Posts: 6, Visits: 38
Some problems with the Navigon 8410:
The following scenario:
1. Rotate screen
2. Go to Route --> Route Editor: after choosing this, it is not possible to go back, since the "back" button
appears outside the screen. Any ideas to go back?
I tried to use the power button (for a short period) and turning ait back on. The image is scrambled after.
I have to shut down the device totally to recover. This is not favourable during flight.
