I installed SD on a Navigon 8410 - with a big thanks to Pink Leader for the memory card files - and it is working OK .... of sorts. The programme starts and runs fine and I have to say at this point I am extremely impressed with the software. It is way ahead of anything else out there including the £1,000+ offerings. However when I want to edit, save or need to type in a destination the keyboard does not appear as it does on the 7" unit. The same if I click on the toggle keyboard under system menu as nothing happens. Another problem, but one I could live with, is that clicking the exit button on the system menu causes the Navigon to freeze which also happens if I click exit on the start up screen and needs to be switched off to reset.
This happens on both version 1.4.4 and the beta 1.4.5 so I believe it to be the unit software rather than SD but if that makes me sound like I know what I am talking about, then I can assure you that I do not!
Hope someone has had the same problem and knows a fix?
It has a screen brightness of 400 NITS and if you look elsehwere on forums like PocketFMS you will see that its recognised as the brightest of winCE devices.
I also have the aware device which is less bright but pretty usable. For reference ipad is about 300-350NITS. It is noticably less bright than 8410.
Do not know data for other Navigon.
Cheers
D
