Virtual Radar Airspace bug in latest iPad version
SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)SkyDemon Team (708K reputation)
Thank you. This is almost certainly a regression introduced by our comprehensive handling of the issue dealt with earlier in this thread. While we (hopefully) solved the turningpoint-at-vertex issue we stopped detecting the turningpoint-on-edge case. This is quite rare - it will only happen when you've a turning point lying exactly on an airspace boundary - but as you can see, Liverpool is just one case. We have introduced a fix for the turningpoint-on-edge case, and this will be in the next version.
FlightDek
FlightDek
Too Much Forum (767 reputation)Too Much Forum (767 reputation)Too Much Forum (767 reputation)Too Much Forum (767 reputation)Too Much Forum (767 reputation)Too Much Forum (767 reputation)Too Much Forum (767 reputation)Too Much Forum (767 reputation)Too Much Forum (767 reputation)
Posts: 8, Visits: 15
Just a quick update.  I tried a couple of direct routes with the following
EGGP -> EGBK: CTA shown for the whole route.
EGBK -> EGGP: Works fine.
EGGP -> EGBO: CTA shown for the whole route.
EGBO -> EGGP: Works fine.
This applied to both the PC and Android versions.
Cheers
Dek
FlightDek
FlightDek
I have the same problem in Android and on my PC.  Both updated in the last week.  PC - 3.6.1.0.   Android - 3.6.1.19137
Flying from Liverpool, if the origin is the Liverpool airport ref point then the virtual radar shows the Liverpool and Manchester CTAs for the whole route.
http://forums.skydemon.aero/uploads/images/ef385849-8e8d-4297-9d24-5449.jpg
However, selecting another part of the airfield stops this.
http://forums.skydemon.aero/uploads/images/40e44eb6-480e-4351-bc47-32fc.jpg
Any ideas?
Dek
genefilter
genefilter
Too Much Forum (622 reputation)Too Much Forum (622 reputation)Too Much Forum (622 reputation)Too Much Forum (622 reputation)Too Much Forum (622 reputation)Too Much Forum (622 reputation)Too Much Forum (622 reputation)Too Much Forum (622 reputation)Too Much Forum (622 reputation)
Posts: 5, Visits: 51
Great, thanks for letting us know Tim !!
Thanks, this problem has already been picked up and addressed ready for the 3.6.1 release. It's actually happening because WAL forms part of your route, as well as forming one of the vertices of some bits of airspace you're going through.
T67M
T67M
Too Much Forum (23K reputation)Too Much Forum (23K reputation)Too Much Forum (23K reputation)Too Much Forum (23K reputation)Too Much Forum (23K reputation)Too Much Forum (23K reputation)Too Much Forum (23K reputation)Too Much Forum (23K reputation)Too Much Forum (23K reputation)
Posts: 206, Visits: 3.2K
Looks to me like it's affected by whether your planned leg crosses or flies along the edge of the airspace a little bit south of your waypoints. I seem to recall a similar bug with waypoints on the edge of airspace was found a few months ago and fixed with typical SkyDemon efficiency.
genefilter
genefilter
Hi
Just been using the very latest iPad version today, v3.6.0 and noticed an airspace bug on the virtual radar
I had created a user waypoint just north of Liverpool's CTA just abeam Formby Point VRP
I noticed that when I change the track to use the user waypoint , the virtual radar shows my complete journey (I had planned due North up to Barrow) now in blue showing I am in Liverpool's CTA (from 1500' to 3500')
http://forums.skydemon.aero/uploads/images/9782c4f8-3eea-420a-aa82-0e93.png
If I move off the user waypoint by the smallest margin, the virtual airspace radar is depicted correctly (ie. the CTA is not shown at this point as I am outside it)
http://forums.skydemon.aero/uploads/images/44296d5e-905d-464f-a738-82f2.png
Here are a couple more screenshots showing 2 more adhoc waypoints that do or don't show the bug
http://forums.skydemon.aero/uploads/images/c4470fdf-27d8-42c2-a864-3474.png
http://forums.skydemon.aero/uploads/images/4928622f-9159-4746-9a7b-2ee1.png
Hope this helps
genefilter
