How to extend VOR radials
André
André
Posts: 24, Visits: 58
Hi!
The title says it all. In the map on my iPad, how do I extend VOR radials? I am planning a route which takes me on a 180 degree southbound direction and I want to follow this course till I intercept he 45 degree outbound radial of a VOR southwest of my location. In the map I would like to extend the VORs radials to see which exact radial would be best to track...
How can I do this?
Thanks!
There are two ways of doing this:-
1. Long press on your chosen VOR, select the VOR from the list in the pop-up window, and select Track Waypoint. The position report at the top of the screen will then provide you with a continuously updated distance to the VOR and which radial your are on. When you see your desired radial appear in the position report, you will know that you have intercepted it.
2. Long press on your chosen VOR, select the VOR from the list in the pop-up window, and select Track Radial. Enter the value of the radial you wish to intercept and hit enter. SD will then draw a narrow magenta line out from the VOR along the line of your chosen radial so that you can see when and where on the chart your track intercepts the radial. As before the position report at the top of the screen will provide you with a continuously updated distance to the VOR and which radial you are on.
Needles to say, you need to be in flying or simulation mode.
Hope this helps.
6575, SD 4.2.2
