SkyDemon Flight Planning
SD and Windows 10
SD and Windows 10
1
2
Next
Jump To Page
SD and Windows 10
SimonM
SimonM
posted 8/12/2015 6:12:03 AM
HOT
Visits: 63
Having recently updated to Windows 10 I now find that I am unable to add additional charts (tried Germany, Italy and Slovenia) as each time I get a pop-up stating that SD has stopped working and needs to shut down.
I have tried uninstalling and reinstalling Skydemon (Ver.3.3.2.0) but to no avail.
Has anyone else experienced this?
Edit to add:- It's the standard Skydemon charts (top choice in the drop down selection) that I am attempting to install
Edited
8/12/2015 6:18:36 AM by
SimonM
posted 8/12/2015 11:00:03 AM
Posts: 8.2K,
Visits: 9.7K
Could you share a screenshot, including as much of any error message as possible?
LeonL
LeonL
posted 8/12/2015 12:50:56 PM
Visits: 55
I've added Italy and Austria with no problems
Leon
SimonM
SimonM
posted 8/12/2015 1:19:23 PM
Visits: 63
Edited
8/12/2015 1:22:55 PM by
SimonM
SimonM
SimonM
posted 8/12/2015 1:20:39 PM
Visits: 63
Screenshot added in post above as per request.
posted 8/12/2015 1:26:43 PM
Posts: 8.2K,
Visits: 9.7K
Is there a debug file in your My Documents\SkyDemon folder? That might include information if it's an error we can catch and analyse within SkyDemon.
This doesn't appear to be a general problem as lots of people have upgraded to Windows 10. I wonder if it's stopping SkyDemon from being able to write the chart data it's downloaded to disk or something.
SimonM
SimonM
posted 8/12/2015 1:39:04 PM
Visits: 63
Tim Dawson (8/12/2015)
Sorry Tim, Can't see one...
posted 8/12/2015 2:40:25 PM
Posts: 8.2K,
Visits: 9.7K
That is unfortunate. It means there isn't anything for us to go on. I'll keep thinking about it.
SimonM
SimonM
posted 8/12/2015 3:17:21 PM
Visits: 63
Okay, tried to delete the chart for Spain and recieved a different error.
The content of the dialogue box is as follows......
System.ArgumentOutOfRangeException: Non-negative number required.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.Generic.List`1.RemoveRange(Int32 index, Int32 count)
at Divelements.Aviation.Managers.TownManager.EntitiesRemoved(Town[] towns)
at Divelements.Mapping.Managers.EntityManager`1.RemovePackage(EntityPackage`1 package)
at Divelements.Aviation.DataManager.<>c__DisplayClass35.<GenerateAddDataDelegate>b__2e()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.8662 (QFE.050727-8600)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 3.3.2.25652
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SkyDemon.exe
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Version: 3.3.2.25649
Win32 Version: 3.3.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Aviation.DLL
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.SandGrid.DLL
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.105.0
Win32 Version: 3.0.105.0
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Divelements.Mapping
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files%20(x86)/SkyDemon/SandBar.DLL
System.Web
CodeBase: file:///C:/WINDOWS/assembly/GAC_64/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
enabled.
For example:
<configuration>
</configuration>
I have also tried adding chart by using windows 7 compatibility settings (i was running win7 prior to the win10 install). This allowed me to successfully add and remove charts as required. So at least this is a work around for now.
Edited
8/12/2015 3:19:42 PM by
SimonM
SimonM
SimonM
posted 8/12/2015 7:57:49 PM
Visits: 63
Another update....
If I select to run Skydemon.exe as Adminstrator then installing the charts is not a problem.
1
2
Next
Jump To Page
