Multiple Timers...
dave_kent
dave_kent
Posts: 37, Visits: 2.1K
Flying on Saturday I kept getting my Freda check timer popping up at irregular, but less than 10 minute intervals.  I suspected duplication and looking in the "timers" option today I can see 4 occurrences of the Freda timer (I've only ever set up one).  I don't know what caused this, but it's easy enough to correct by deleting the extra 3.
Pete
Pete
Posts: 129, Visits: 966
I have also had that issue, unsure when exactly occurred a few weeks ago.
Android 5.1
Pete
Pete
Ah....it occurs when using setup/ load settings from cloud. Each time I do this it duplicates my timer.
Could this be looked into please?
Nexus 7, 5.1.1
Pete
Thank you for identifying how this is happening. Yes, of course we will fix this bug.
And another one (bug) bites the dust. Wink
Pete
Pete
Thanks Tim!
JohnEdgley
JohnEdgley
Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)Too Much Forum (84 reputation)
Posts: 2, Visits: 8
Following on from this thread. Flying on Monday, had just two timers loaded that were then duplicated literally hundreds of times each, popping up one after the other. So much so that could not delete them all during the length of my flight. Has not happened before so wondered if a result of any upgrade. Any fix known please except deleting each line individually. Really want to make sure this doesn't happen next flight.
John
efrenken
efrenken
Posts: 265, Visits: 3.5K
I'm experiencing the same for the last couple of months, and I don't use save/load settings from the cloud at all.
I regularly delete duplicate timers, but they keep popping up (latest iOS and SD on iPad Air).
Eric
That's weird. Can you reproduce this by logging out and back in again, perhaps it happened then?
efrenken
efrenken
When I started using SD I defined a persistent timer 'Tank umschalten' (meaning 'switch fuel tank' in English). At one point I decided to introduce English as my main language on board, so I deleted the German timer 'Tank umschalten' and created a new one 'switch fuel tank'.
If I use SD now, showing only the English language timer, and then log out and in again, the German language timer reappears, additionally to the English language timer. If I log out and in again another time, SD shows
Switch fuel tank
Tank umschalten
Tank umschalten
The German language timer is added once more each time I log out and in again.
While doing these tests I noticed all surface features are activated automatically when I log out and in again. Is this a bug or a feature?
Eric
Edited 9/26/2016 8:51:53 PM by efrenken
