Further to my earlier post above, having said that I have experienced no screen time outs since upgrading to Android 5.0.1 which was based on 2 x 1 hour flights in simulation mode last night, today it is a different kettle of fish. Today, in simulation mode, the screen times out at whatever interval has been set in the system settings
Furthermore, I am experiencing the following additional problems:-
1. In simulation mode, a change of screen orientation causes the SD orb to obscure the time and distance blocks (I thought this was supposed to have been fixed?);
2. Invoking
Simulate WITHOUT planning a route, SD exits to the desktop immediately. After going back into SD several times (it varies, but usually between 2 and 4 times), invoking
Simulate works as it should initially, but a change of screen orientation again causes SD to exit to the desktop immediately;
3. Invoking
Simulate WITH a route planned, SD works as it should initially, but as above, a change of screen orientation causes SD to exit to the desktop immediately.
I have tried logging out of SD and back in again, but it makes no difference.
Of course, SD may behave differently in flight, but I have not yet had a chance to check this out. Even so, this needs to be fixed.
PC – Windows 10 (Home Ed) Version 22H2, Build 19045.6396, SD 4.1.2
