Posts: 8.3K,
Visits: 10K
I have heard that point of view before, but I don't understand it. If you've done some manoeuvring and need to reorientate yourself, you have two options, assuming that we creating this bearing instrument:
1. Look at the bearing instrument, imagine it says 179 degrees, and look at the track instrument, imagine it says 314 degrees. You have to mentally work out which way to turn, and by how much, then execute the turn while comparing the values to see when to stop turning. 2. Look at the map, where you have a clear magenta line pointing towards your next waypoint and a big line projecting from the front of your aircraft, from which you can quickly determine which way to turn and how big a turn to make.
I suppose I just don't understand how the potential solution given in option 1 is better in any way than the current solution which is option 2. Then there's always the course correction indicator, which is a collapsed version of the compass rose at the bottom of the screen, which simply shows you which way to turn and by how much. Even that is a simpler proposition than option 1 above, and it already exists.
