Persistent Timer
kobaje
kobaje
Posts: 28, Visits: 205
Thank you Eric! You solved it! No bug, just a stupid user ;-)
efrenken
efrenken
Posts: 265, Visits: 3.5K
Hi Jens,
for me it works at it should. Have you tried to delete the timer as you would delete other things on your iPad? (Swipe with your finger from right to left over the item and then press delete on the appearing button)
Regards Eric
kobaje
kobaje
I created a persistent timer in SD for iPad and dont't know how to disable it. I can change the values but can't remove it. Looks like a bug. Thanks for your help!
Jens
