Wrong Specific Gravity used for MOGAS Mogas 80/90
rosdol
rosdol
Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)Too Much Forum (8.1K reputation)
Posts: 48, Visits: 215
as I noted in another thread (Aircraft Profiles) you calculate the Mogas weight by using 0,75kg/l which is wrong. The acceptable Standard for 80/90 Octane Mogas is 0,72 kg/l. This gives a diffrence of some kg in your W/B calculation.
Can you please correct this in a new release ??
thansk
Erik
What is your source reference for this data, please?
Wikipedia lists the density of automotive fuel between 0.71 - 0.77 kg/l. Avgas is 0.68 - 0.72 kg/l. Higher ethanol content raises the density. Higher grade gasoline also tends to be denser. So it is really up to you what you use. I think 0.75 kg/l is not at all unreasonable.
rosdol
rosdol
Re Tim,
in most POH's I have read the Mogas or Avgas specific Gravity used for calculating the W/B is 0.72.
Erik
Well, what can I say. It is what it is, whether it's in the POH or not. I think it has legal ramifications, though. When you use the POH value your a** is covered if you use it...whether it's right or not.
