Visits: 17
Hi, and thank's to both of you. I followed your advice and shotdown my background apps. However, I shotdown one at the time and finally I found out that if I shotdown my WiFi the Bluetooth GPS device worked as smooth as it was intended. I think the reason is that if you have the "Apple-WiFi" on at the same time as the Bluetooth GPS device, the Mini uses the "Apple-WiFi" as the primary source to search for sattelites for the Location Services; easy to understand when the clue is found!
BR Thomas
