Sync with Mobile
JonathanB
JonathanB
Too Much Forum (769 reputation)Too Much Forum (769 reputation)Too Much Forum (769 reputation)Too Much Forum (769 reputation)Too Much Forum (769 reputation)Too Much Forum (769 reputation)Too Much Forum (769 reputation)Too Much Forum (769 reputation)Too Much Forum (769 reputation)
Posts: 8, Visits: 19
I'm having issues getting my WinCE based device to be seen properly in Windows 7 running in VirtualBox on my MacBook - although it does appear as "Microsoft USB Sync", SkyDemon does not recognise that it is connected. Actually it is an Airspace Aware device, and that software's sync program can't find it either, so it's likely either a Windows 7 problem or a Virtualisation problem.
Anyhow, is it possible to just copy the appropriate files across to the device manually? The routes, user waypoints and notams files are self-explanatory, but I want to make sure that any airspace updates are also copied over and those files are less obvious.
Thanks for all the support!
Jonathan.
If you've got a USB memory stick handy, put it in, and run the SkyDemon Mobile installer. It will list the memory stick as a removable device and allow you to "install" SkyDemon Mobile to it. That will show you the file/directory structure required, and where all the charts go.
