Route save
Skyhawk
Skyhawk
Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)Too Much Forum (149 reputation)
Posts: 2, Visits: 32
Hello SkyDemon team,
in 2.6.3 trial version I am unable to save selected route. I can name it but there is no "save" button. If I press the screen somewhere around, route window disappear and route is not saved.
Before update (2.6.2) it worked well.
Android, v 4.2.1, ASUS Transformer Infinity is used.
Am I doing something wrong?
Also, I cant choose aircraft profiles althought they are in aircraft folder with correctly named extension.
Thank you for any help.
Edited 6/10/2013 6:38:57 PM by Skyhawk
Posts: 8.2K, Visits: 9.6K
When you have finished typing the filename, press the return key on the keyboard. This is the way it has always worked.
If you are placing new aircraft definitions in the Aircraft folder manually, you will need to terminate and restart the SkyDemon software before they will be loaded.
Skyhawk
Skyhawk
Ah, you are right, "return" key did work. Thanks a lot! Maybe the problem was keyboard on dock station.
Anyway, loading of aircraft does not work even after restart. I can see new aircraft if I make it through SD, but not downloaded from this forum. It is same as with route - if I create route in SD for Android, find the file, move it to different folder, rename, move it back - SD cant see it.
Maybe your device needs restarting before those files will be made available to SkyDemon. That's beyond our control I'm afraid.
