Would you like to see a range feature in Skydemon
B2Spirit
B2Spirit
Posts: 24, Visits: 158
Hi all. I am wondering if you also miss a feature like the high-end glass cockpit features like the range circle related to fuel wind and current speed.
I have e-mailed Tim and asked for a feature, apparently I am the only one who has asked for this so I am starting a poll investigate if there are other like me that would like this feature.
This is what I would like to see:
In the planning mode, I would like to see a range circle of the aircraft in use visible on the map. This would relate to the current planned fuel, the wind and the speed (in the aircraft profile). A function with no wind would be good. Anouter circle for the reserve range would also be good.
In the flying mode. I would like to have the same information, but calculated by the current speed, so I will be able to see estimated range, based on the current speed, wind and fuel.
There might be other ways to do this but this is roughly, what I would like to see.
Please vote yes, if you find this to be a god idea and a feature you wish to have implemented in Skydemon.
EDIT: I triedto make a poll but did not succeed
Edited 6/4/2013 11:41:11 AM by B2Spirit
Bouwair
Bouwair
Posts: 39, Visits: 2.8K
Yes i would also like this proposal implemented in SD
grt
Bouwair
Yes, that would be useful.
In planing I imagine a circle drawn around the current last point of the route with a darker inner circle showing the safe range and a lighter outer circle (actually an annulus if you want to be anal Smile) reaching up to bingo time. Winds should be the same ones used for planning now. If you want to be even fancier, you could draw the range around every point along the route with a live update. That would allow you to see at one glance up to where you can reach from any point on the route.
In flight mode this shold be a selectable option for display since I am leary to clutter up the display. And, if current winds are available, use those for range calculation. And it would, of course, only be drawn around the current location.
That would be a great feature!
Edited 6/4/2013 3:26:04 PM by ckurz7000
mr_rodge
mr_rodge
Posts: 22, Visits: 70
Sounds good.
Runways
Runways
Posts: 309, Visits: 1.6K
Can you please confirm that by: "range circle related to fuel wind and current speed.", you are referring to Endurance and not gliding range?
If you are referring to neither, would you please elaborate?
Many thanks
Very Newbytheway
DurhamTeaseAirport
B2Spirit
B2Spirit
Hi, english is not my native language.
I will try to explain. For instans, if my airplane, have fuel for 5 hours, and the IAS is 100kt then it should be possible to draw a circle around the airplane that shows how long i could fly in those 5 hours, from my starting airport. If I have 20 kt head wind, my range will be less than if I have 20 kt tail wind, this should be calcualted for.
When airborn the circle should be drawn related to my current speed (my guess ground speed from the GPS) so that my range would be related to my actual range, if possible.
Gliding range is already included in the Skydemon.
Did this answer your question? If not I will try to explain again.
Runways
Runways
OK, that is understood. The range is also varies according to leaning the fuel mixture (fuel flow) which can affect the amount of fuel used per hour.
Naturally the longer we fly the smaller the circle is going to be. Having said that some aeroplanes (mine included) have a range of over 6 hours. This can translate into 700-1000 miles range depending on the the prevailing conditions, some of which you mentioned already.
Flying from the middle of England (say Leeds & Bradford airport as an example) and using the usual chart (1/500000) one can expect the circle we are talking about to be drawn well within the Mediterranean sea southwards and almost hitting Reykjavik in Iceland northwards. I wonder how useful such a feature may be for GA.
I am interested to know your opinion about the above
Very Newbytheway
DurhamTeaseAirport
Edited 6/6/2013 12:27:12 PM by Runways
I see your point. Maybe the range should only be drawn if it drops below a user selectable threshold which can be specified in the aircraft settings. Setting the threshold range to zero would effectively turn this feature off.
Another point to ponder is zoom level. There's no point drawing the range circle if it extends well past the map region currently displayed.
So, draw the range circle (it's not going to be a circle with wind present) only if endurance or range drops below a predetermined value and the map area currently displayed is larger than the computed range.
B2Spirit
B2Spirit
Reply to Runway
Hi, thank you for your reply.
Regarding the leaning question. In my aircraft profile, I have entred the fuel flow for best performance, and i know that my fuel flow is 8,8 gph. So I do not see your leaning problem, but then again the world is not perfcet. This would be an indication.
My initial idea to this feature was during planning a long trip. I wanted a way to see fast and easy my range was from my initial starting point. I wanted to know how many fuel stops I should plan for and so on.
If the range circle is useful for short trips with full fuel? I don't know. Maybe not with a large range. But then again, I tried to set up a poll, one answer for yes and one for no. Maybe your answer in this case is no, this may not be usefull for all. However this is a feature I would like to have and would find usefull.
There are features in Skydemon that I do not use or find useful, some of these features may be very useful for other users.
Edit: att Runway
Edited 6/6/2013 6:52:53 PM by B2Spirit
Runways
Runways
Hello B2Spirit, Many thanks for the clarification. I actually didn't say No or Yes for this feature.
I must admit so far as fuel is concerned, I tend to carry far more fuel than what I need at times. Worse still I mostly tend to fill-up the tanks to their maximum. This means I am guilty of wasting so much energy ferrying all this extra weight around on the off chance that it may be needed, be it for an unexpected lengthy diversion, sudden leak tank leak or whatever, all of which I have encountered in the past. I just feel more comfortable with the fuel in the tanks and not in the bowser as the saying goes.
I have to say what you are suggesting is not something I thought about before, but now that you've mentioned it I am trying to think how I/we would use such an addition so as to recommend it.
You may have a point that I am missing. However, to gain more support, it would be wise to spell out in detail how useful this suggestion can be.
Very Newbytheway
DurhamTeaseAirport
Edited 6/7/2013 12:36:10 PM by Runways
