Would you like to see a range feature in Skydemon
http://forums.skydemon.aero/Topic9511.aspx
By B2Spirit - 6/4/2013 11:37:51 AM
Hi all. I am wondering if you also miss a feature like the high-end glass cockpit features like the range circle related to fuel wind and current speed.
I have e-mailed Tim and asked for a feature, apparently I am the only one who has asked for this so I am starting a poll investigate if there are other like me that would like this feature.
This is what I would like to see:
In the planning mode, I would like to see a range circle of the aircraft in use visible on the map. This would relate to the current planned fuel, the wind and the speed (in the aircraft profile). A function with no wind would be good. Anouter circle for the reserve range would also be good.
In the flying mode. I would like to have the same information, but calculated by the current speed, so I will be able to see estimated range, based on the current speed, wind and fuel.
There might be other ways to do this but this is roughly, what I would like to see.
Please vote yes, if you find this to be a god idea and a feature you wish to have implemented in Skydemon.
EDIT: I triedto make a poll but did not succeed
By B2Spirit - 6/12/2013 10:57:02 PM
Thank you for that information. Anything else than an fuel sensor/flow sensor is guess work anyway. It is just the way it is represented.
