Robin 200 & W&B problems
jtuggey
jtuggey
Too Much Forum (411 reputation)Too Much Forum (411 reputation)Too Much Forum (411 reputation)Too Much Forum (411 reputation)Too Much Forum (411 reputation)Too Much Forum (411 reputation)Too Much Forum (411 reputation)Too Much Forum (411 reputation)Too Much Forum (411 reputation)
Posts: 2, Visits: 7
Dear All,
I've read the forums and also the help on skydemon website for how to setup the W&B.
However, I seem to be struggling.
The w&B 'polygon' has the correct numbers on x & y axis, to reflect exactly that in the PoH (x axis m.kg, y total weight, kg)
However despite various attempts at putting the invidual moments for passenger, fuel etc., the 'X" is way off the graph (which is not the case when I do this manually).
I'm a little confused about whether I need to redo the x-axis. Can anyone help please?
Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)Too Much Forum (74K reputation)
Posts: 593, Visits: 4.9K
Post all your numbers and I'll try to help
jtuggey
jtuggey
Posts: 2, Visits: 7
Stevelup,
Many thanks for the prompt and helpful reply!
The coordinates from the PoH are, in clockwise direction:
95,400
125,575
250,780
360,780
180,400
Units are x axis, m.kg and y axis kg
CofG limits are +0.32 to +0.46 at 780kg
max authorised weight 780kg
Basic weight is 549kg
CofG is 0.268m aft of datum, of which total moment about the datum is 147kg/m
Arm for pilot + passenger are 0.45m
Baggage 1.2m
Fuel 1.1m (max is 85kg)
Hope that helps - really appreciate you looking at this for me.
You've got the same issue as the other poster I replied to. Your envelope is for a moment, not a CG
Also, it's a bit confusing as your empty weight is 576kg yet your graph starts at 400kg
I found another POH online here - I accept that it's not necessarily for the same aircraft, but the rest of the values are the same.
This gives a loading envelope of:-
22,580, 32,780, 46,780, 46,580
(this also matches the figures you gave of .32 to .46 at 780kg)
