You've got the same issue as the other poster I replied to. Your envelope is for a moment, not a CG
Also, it's a bit confusing as your empty weight is 576kg yet your graph starts at 400kg
I found another POH online
here - I accept that it's not necessarily for the same aircraft, but the rest of the values are the same.
This gives a loading envelope of:-
22,580, 32,780, 46,780, 46,580
(this also matches the figures you gave of .32 to .46 at 780kg)
