C172M
screetch82
screetch82
Posts: 123, Visits: 176
hi
see the attached aircraft file. How many of you are using and setting up files?
Feel free to test and all comments are welcome.
I would appreciate holding fuel usage figures
C172-GBDNU.aircraft (1.1K views, 936 bytes)
screetch82
screetch82
in order to download the file
(1) sign in the forum
(2) clicking on the file select "save target as".
(3)For me it wanted to save it as an xml file.
(4) Start Skydemon -->Data-->Aircraft -->Import-->Browse to the file
tidderae
tidderae
Too Much Forum (254 reputation)Too Much Forum (254 reputation)Too Much Forum (254 reputation)Too Much Forum (254 reputation)Too Much Forum (254 reputation)Too Much Forum (254 reputation)Too Much Forum (254 reputation)Too Much Forum (254 reputation)Too Much Forum (254 reputation)
Posts: 2, Visits: 27
Hi Screech,
Just running the demo version of SkyDemon and very impressed. I own and fly Cessna 172N with long range tanks. Tried sorting out the weight and balance in the program and got a bit confused. Checked the forum and note you have aircraft files for 172N. Tried to download but the Mozilla crashes every time. I am running Vista Home Premium on an HP Pavilion Laptop, any ideas how I can access your files
Tony
screetch82
screetch82
i also have firefox. Once you are logged into the forum just left click on the file and it will ask you
where you want to save it. But it in the skydemon folder. When you Started skydemon go to
"Data" --> "aircraft" -->"import" and browse to the downloaded file.
If you still got issues give me your email and I will email it to you.
However you may still want to double check that the weight and balance, and COG is close to your aircraft
Flybynight
Flybynight
Posts: 14, Visits: 90
How does the 172M vary from the 172N? I can't find details of the 172N on the forum, or the PA28-161 either. I'm surprised as both of these are very common aircraft. Maybe I'm not looking in the right place?
Flybynight
screetch82
screetch82
Hi well the N is newer than the M. However check your POH for full details. I have not altered the Aircraft file to suit the new options you get in SD V2.0 yet.
You can assume the weight and balance is roughly the same and will give you a good starting point for the aircraft you fly.
I use the file I have posted and then modify for each specific aircraft that I fly. Just rename it to the callsign of the aircraft so you alsways pick the correct one.
