C172M
http://forums.skydemon.aero/Topic895.aspx
By screetch82 - 8/10/2010 3:37:31 PM
hi
see the attached aircraft file. How many of you are using and setting up files?
Feel free to test and all comments are welcome.
I would appreciate holding fuel usage figures
By screetch82 - 2/19/2011 10:15:42 PM
Hi well the N is newer than the M. However check your POH for full details. I have not altered the Aircraft file to suit the new options you get in SD V2.0 yet.
You can assume the weight and balance is roughly the same and will give you a good starting point for the aircraft you fly.
I use the file I have posted and then modify for each specific aircraft that I fly. Just rename it to the callsign of the aircraft so you alsways pick the correct one.
