2.6.0 SD crashes when I try to create a WP
knorren
knorren
Posts: 26, Visits: 335
When I point on a spot on the map and choose Create Waypoint the SD program crashes to desktop on my Ipad 3.
Any suggestions?
What is your position format set to under the Change Units screen? And where on the map are you touching?
www.pilotenshop.net
www.pilotenshop.net
Posts: 8, Visits: 62
i have the same problem.
Settings :
Grad,Minuten,Sekunden => OK
Grad,Minuten => App crashes and closes
Best regards
Dietmar
www.pilotenshop.net
www.pilotenshop.net
Settings :
Best regards
Dietmar
knorren
knorren
I confirm what Dietmar says Smile
Peppeke
Peppeke
Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)Too Much Forum (79 reputation)
Posts: 1, Visits: 20
Exactly same happens in my Nexus 7.
Otherwise all works satisfyingly (for the present). Testing continue...
Best Regards
Pepe
Edited 4/3/2013 11:17:37 AM by Peppeke
Thanks, I think we have now found the cause of this issue and a fix will be in the next update.
