SkyDemon Flight Planning
2.6.0 SD crashes when I try to create a WP
knorren
knorren
posted 3/28/2013 9:27:30 AM
Visits: 335
When I point on a spot on the map and choose Create Waypoint the SD program crashes to desktop on my Ipad 3.
Any suggestions?
posted 3/29/2013 12:36:56 PM
Posts: 8.2K,
Visits: 9.7K
What is your position format set to under the Change Units screen? And where on the map are you touching?
www.pilotenshop.net
www.pilotenshop.net
posted 3/30/2013 7:49:22 AM
Visits: 62
i have the same problem.
Settings :
Grad,Minuten,Sekunden => OK
Grad,Minuten => App crashes and closes
Best regards
Dietmar
www.pilotenshop.net
www.pilotenshop.net
posted 3/30/2013 7:49:23 AM
Visits: 62
Settings :
Best regards
Dietmar
knorren
knorren
posted 4/2/2013 6:58:08 AM
Visits: 335
I confirm what Dietmar says
Peppeke
Peppeke
posted 4/3/2013 11:16:03 AM
Visits: 20
Exactly same happens in my Nexus 7.
Otherwise all works satisfyingly (for the present). Testing continue...
Best Regards
Pepe
Edited
4/3/2013 11:17:37 AM by
Peppeke
posted 4/4/2013 5:02:28 PM
Posts: 8.2K,
Visits: 9.7K
Thanks, I think we have now found the cause of this issue and a fix will be in the next update.
