Version 1.3.2 Exiting program from Route Editor.
Max_UK
Max_UK
Posts: 66, Visits: 2.9K
Tim, trying out SkyDemon Mobile, V 1.3.2 in trial mode, & have found a problem?.
When using the route editor, I select "Start Route" & put in Shoreham. Then click "Continue" & SkyDemon shuts down.
This happens on both Navigo V2 4.3" units. Have also just tried a completely fresh install & still get the same result.
Not sure if its just my Sat Navs or a general problem?  Maybe others could confirm?
Regards,
Max
It's not something we've seen here or heard about before. SkyDemon doesn't do anything special when the Continue button is pressed, it merely returns to the map screen. Perhaps you could give us the route in question so we could attempt to reproduce it. Or does it happen with any route?
boredpilot
boredpilot
Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)Too Much Forum (746 reputation)
Posts: 10, Visits: 47
Hi Tim I can confirm same error when I tried that was well on mine.
Also when i press route and then new, it does nothing, I have to use route edit to be able to input data but it then does exit out of the program.
Thankfully my normal routes are already created.
Any ideas
We've managed to reproduce this, thanks for reporting it both of you. We'll get a new public release out soon, but if in the meantime you'd like a hotfix build that sorts the problem out, contact us directly.
Cheers!
