NOTAMS
pink leader
pink leader
Posts: 518, Visits: 2K
OK. Was probably my fault. But with latest beta version 1.3.3 build2, NOTAM window OK on all 3 mobile devices (8410, loox560 & cheapo chinese)
TAFs & Metars available via Active Sync in loox, via wifi in cheapo BUT no way of getting into 8410 (no web access, Active Sync does not work on 8410).
Not that bothered since iphone app does TAFS & Metars extremely well (aeroweather). But if and when Tim gets more comprehensive wx feed, then this will matter.
Suggest that an option to transfer wx data during card sync wd be v useful  .. once full wx info.
D
pink leader
pink leader
Although clock is now reset within SD mobile, this does not seem to be being used by NOTAMs. Synced 8410 via card and booted up. Notams not visible on map.
Turned of & got normal car GPS to get a fix and update clock.
Reloaded SD.
NOTAMs visible.
Any ideas?
D
As we said before, you need a device where the clock is set right in order for SkyDemon to load NOTAM on startup. SkyDemon will now update the clock, but it doesn't reload NOTAM whenever it does so.
