NOTAMS
http://forums.skydemon.aero/Topic715.aspx
By Steve - 7/9/2010 11:18:34 AM
Hi, I am using both the plan and inflight system, and when I sync the two together (activesync) it says that it is syncing NOTAMS to the mobile device (amongst other things), my question is does that actualy sync the (route/all) NOTAMS to the device ?
When I look at the mobile device I can't see any NOTAMS, even with a route selected etc.
Could you please explain exactly how this function works to allow the inflight system to warn of any NOTAMS.
Many thanks, Steve
By Tim Dawson - 8/20/2010 3:08:39 PM
As we said before, you need a device where the clock is set right in order for SkyDemon to load NOTAM on startup. SkyDemon will now update the clock, but it doesn't reload NOTAM whenever it does so.
